In replacing weatherboarding I have found a seriously rotted cill plate and the adjoing ends of wall beams are rotted also. (Not listed barn conversion)
These wall beams will be behind the internal wall surface so the repair is not an exercise in aesthetics.
I intend replacing the cill plate and ideally the beams with green oak of a similar dimension to the existing ones. I would like to cut tenons on the beams and mortice the cill to take the tennon but my dilemma is how to insert the tennon. The top end of the wall beam enters a beam supporting the roof.
The SPAB pamphlet on timber repairs indicates cutting a wedge shaped piece of timber from the cill sliding the the tennon in, from the side, and then replacing the wedge. Whilst I can make cuts vertically in the timber at an angle to the edge, how do you make the cut longitudinally in the cill to release the wedge.
Alternatively I could just replace the ends of the wall beams which would alleviate the problem of how to insert the tennon, but would I feel leave a point of weakness where the new and old beams are joined by a scarf joint. The un-rotten vertical timbers show some sign of bowing and general wear and tear so ideally I would like to add to the strength and was thinking of adding a doubler alongside.
I could of course cheat and fix the new uprights using stainless steel or galvanised brackets and coach bolts, but then I feel I should not visit this website again.
