Back again having semi-sorted the walls issue - got a specialist out to have a look and quote etc
Unfortunately he wasn't able to do the chimney and roof for me. So would be very grateful for a bit of advice on potential costs for these.
The house is at least 400 years old and the roof is handmade plain clay tiles. The front half is a plain gable, the back is a catslide and then there is a hipped roof over a small 1970's kitchen extension. Also a very poorly built 70's dormer with flat roof on the catslide. There is no ridge-beam.
Roof is fixed to timber battens with bituminous roofing felt underneath. There is no ventilation to the roof at all. Insulation is rigid insulation board that has been pushed in fully between the rafters with no gaps.
A good 30% of the tiles are broken, slipped and/or spalling including ridge tiles. The ridge tiles have been mortared with Portland cement as have the verges. The roofing-felt is rotted away at the eaves and the gutters/pipes are corroded and need replacing. There is evidence of water ingress at one point in the ridge, but minor at present.
The top of the chimney is in a dire state and needs rebuilding and repointing. Lead flashings all need replacing and the valleys and the flat roof are an unknown at present.
The surveyor (specialist in timber-framed buildings) has recommended that we should basically strip the whole roof, install a membrane, install insulation and nail battens to the rafters to allow ventilation (if I understood correctly), then retile with what can be saved mixed in with either reclaimed or new hand-made tiles. He'd also like us to redo the dormer if possible as the construction is appalling and the design is not in keeping with the house (no LB permission on it and LBO would like it replaced with something more sympathetic).
I'm not sure how to calculate the roof area - I did count the tiles on the smaller roof at the front and there were approx 1800! It's not a big house, but catslide roofs add a heck of a lot of acreage!
As we were wanting to negotiate on our final offer asap, I called a couple of builders who I know do this kind of work - one of whom has retiled my parents similar age cottage but a long time ago. Neither work in the area, so there is no incentive for them whatsoever.
The advice I was given was that if 30% of the tiles looked bad just from peering at photos and out of the window, then you could call it at least 50% by the time the roof was stripped and that a complete re-roof would be more economical in the long-run than endlessly patching.
Just based on what I said and a few photos, I was advised that it would be at least £20k to do all the work and possibly more like £30k by the time we'd encountered all the unknowns and including scaffolding and using a builder who knows a bit about C16th buildings.
We are in SE England in a pretty expensive kind of area.
I checked back with the surveyor and he said that £20-£30k sounded about right to him.
Does this sound utter madness and it should be more like £10k or is it correct ballpark? We don't want to under-negotiate, but also want to be fair to the sellers.
