Hi All
I'm replacing three oak beams which some may refer to as floor joists. I've got the new ones and have removed the old ones and I have a couple of questions...
The beams are pretty much 10cm x 10cm (4" x 4") and 250cm (8ft-ish) long
1. Do oak beams expand and contract much with temperature or atmospheric moisture changes? If so, how much movement can one reasonably expect over an 8ft/250cm joist/beam?
2. Is it better to alter the cuts in the central beam and wall beams into which the new beams will be fitted or is it better to cut the new joists so that they fit the existing cutouts in the existing beams or doesn't it matter? Having done a few rough measurements, I don't need to make a cut of more 1cm from any beam/joist.
3. Does anyone have any other hints/tips or advice that I can use to get the job done? I'm lucky in that we have very low ceiling height and I can lift each beam above my head without machinery. Additionally the wall beam into which they sit juts out into the room so I can just drop the new joists into them. This does make the job significantly easier.
One tip I can pass on to anyone else working on old beams is that if you're working on your own, you can't accurately tell by looking how much they're flexing/moving when you're on top of them [so it IS worth listening to your wife!]. I thought I was being sensible by sticking to the wall side of the beams and not the middle until I discovered the hard way that one of the old joists was completely eaten at the wall end where it was impossible to see so when I leaned on that end to remove a nail from the next joist, it gave way with a big crack and I came crashing through the ceiling. It was very silly but I thought I'd been quite careful and didn't consider I had been taking undue risks. Fortunately the low ceiling height in our house was a big advantage and I was able to grab the next joist and lower myself down where my foot found faithful Henry hoover who enabled me to step to safety so I was fine, the 'remove ceiling project' was suddenly well ahead of schedule and apart from more cleaning up than planned, no harm was done. (Henry Hoover is far more helpful than the dog who had decided to sleep next to the radiator in that room and opened one eye, gave me a kind of withering look and went back to sleep.)
