Hi All,
I joined to get some advice, really.
We have a Victorian terraced house in Kent. Standard little 2-up, 2-down with an extension at the back and a small cellar below the front room.
The cellar floor was (still is, in parts) chipboard on partially suspended timber over earth, sealed round the edges with expanding foam. The foam doesn't seem to have helped at all.
Anyhoo, I recently put my foot through this moist organic layer and have realised at least half of it is hazardously decayed. I have also been farming wood boring beetles under there so will have to get a chap or chapette in to treat the timbers above and around.
I want to put in a new, inorganic, decay-proof floor.
Having done some browsing, I see that trying to seal the damp out is a losing battle, so I am thinking of some chunky gravel on the earth, topped with limestone flags. I am pondering grouting it - I don't want to seal moisture in but equally I am keen for an appealing appearance -I hope to use the room as a workshop / man-cave.
Can anyone see any problems with my plan, or make any suggestions as to how it could be improved upon (e.g. should I use sand over the gravel, or will this be likely to wick moisture up from the earth below?)
I am currently running a dehumidifier down there which pulls about 5 litres in 3 days but I have not measured the humidity itself.
Looking forward to hearing your thoughts (unless they be horribly expensive and preceded by lots of digital tooth-sucking, of course ;-)
Cheers,
Algy
Cheers,
Algy
