Flyfisher
- Norfolk, UK
Nice sunny day, not too hot, ideal for finally getting around to replacing a broken manhole cover and raising it to be more or less level with the grass instead of about 5 inches below it.
Unfortunately, after clearing away the grass and earth, I've discovered that the actual inspection chamber is larger than the actual cover. It's not easy to see from the photo, but the chamber is about 31x17 inches but the existing cover is 24x18. Width-ways, this is OK, although it means one side of the cover is not supported (which might be why it broke when I drove over it!), but it leaves a gap which appears to have been covered with cement. I suspect the cement was supported during setting by a roofing slate or (as I've found on a previous manhole) a piece of asbestos cement sheeting.
However it has been done, I'm concerned that it won't be strong enough to support anything driving over it so my question (at last, I hear you say) is what would be the best and easiest thing to cover the roughly 8x17 inch gap and [properly support the new manhole cover frame on all four sides?
I'll be supporting the new frame on a course of engineering bricks to raise the new cover to the level of the grass, but I don't want to cover the gap with anything too thick that would mean there is an insufficient layer of earth for the grass to grow. So, something about 1-1.5 inches would be idea. I'm concerned that a paving slab would not be strong enough, but I'm wondering about a concrete gravel board as used for fences - are these steel-reinforced?
I've got some very substantial 2-inch angle-iron but have no idea how long this would last before rusting away.
Any other ideas?
Any other ideas?
