Cloudscape
- Mid-Wales
On the end of a long lean-to section, which badly needs repointing, I have a door (200cm high) with glazing above. The thin lintel looks pretty far gone, and I think the wall is held up by the doorframe. But this frame has been patched and added to, and is rotten in places. (The inner skin of stone has a slghtly better lintel and the lime plaster is still attached.)
The external lintel doesn't look as though it extends into the left-hand wall, and barely laps onto the brick on the right.
As soon as the weather improves, I think I need a new lintel, frame and door. Please could someone with experience tell me how much of the wall is likely to collapse. I'd really like to avoid changing more than I have to. I like the house the way it is.
Should the wall be pointed and consolidated before removing of the wood? Is this a case where needles might work (I've never used them). Any suggestions for order of works would be gratefully received.
