Hello Experts. I am looking for some advice on replacing the section at the bottom of the soil pipe.
Our soil pipe (Plastic, not original) feeds into a ceramic curved pipe that curves about 90 degrees to then feed into the drain.
The ceramic curve is cracked at the top, as I have found when digging down to it to check is was ok. How easy is it to replace this section of pipe? I have never done any drainage works before. Are there any regulations, or is it just a simple - old out, new in swap?
Many thanks Merlin
Many thanks Merlin
