Hi All,
House was built in 1894. Because of it's age will there be anything odd about the mortar/cement (eg: lime?) that I need to know about and how can I tell?
Some of the brickwork is a bit frost damaged and i'd like to get it replaced. If there is anything odd about the mortar do we have to try and use the same old stuff or can my builder get away with using modern cement? Are there any issues?
We're looking to extend. Does the builder need to take anything into consideration when mating modern new bricks to 117 year old bricks?
I'm asking as I seem to remember reading something about damp issues if you're not careful mixing up old and new builds due to the fact lime mortar 'breathes' and allows trapped water to evaporate and modern stuff doesn't?
Finally, I was recently up in the loft and noticed some of the mortar at the very top of the house is a bit powdery and just running my fingers along the mortar was causing it to fall away from the bricks like sand! What the hell is going on here? :shock: Should I be concerned?
Cheers!
Cheers!
