I have a large lime plastered ceiling I'm restoring. The plaster is generally in goodish shape though with some lengthy (2-3m) cracks (some hairline, some double cracks but nothing particularly stepped) running throughout. These join up with hairline cracks in the surrounding cornice which appear to be quite ancient since having stripped off the emulsion and distemper (which I should guess has been up there for the best part of 50 years) some of these cracks appear to have been repaired in the past. On one side of the larger double cracks in the ceiling the plaster appears to have very slightly blown with a mm max of play if pushed. The ceiling appears to be painted in a thin coat or two of emulsion.
Fundamentally, I'm not too worried about the situation as I take the view that the ceiling has almost certainly been up for some 125 years (the house was built in 1880) and is unlikely fall down now (unless I cause it to!)
My "do the minimum" plan is:
- rake out the double cracks and fill with lime plaster (lime putty to sharp sand in 1:3 ratio).
- paint ceiling and cornice with soft distemper.
Two further options occur to me:
- try to strengthen the slightly blown bits of plaster by using washers. But I'm concerned it might do more harm than good;
- remove the emulsion layer and apply a layer or two of limewash before painting with distemper (as I've heard limewash can strengthen the ceiling and that distemper might not like to be painted directly onto emulsion - also could this stop the ceiling from breathing?).
Very grateful for any thoughts.
