Westholme
- Gloucestershire
I intend to replace an external door with a window in my 1894 semi. I have sufficient matching bricks taken from a chimney breast and internal wall to brick up part of the doorway. I want to avoid ending up with a square window at all costs and I think I can replicate exactly an upstairs window on the same wall that was originally a sash one. The doorway is in a cavity wall, with outer skin opening of 2' 6" and internal opening of 3'
I've been on the lookout for a free stone cill and I found one in a house where a window will be replaced by a door. There are a couple of issues, though:
1. The cill is broken. I helped remove it carefully today and it was very disappointing to discover a crack. The cill was intact for 100 years probably until some idiot drilled a hole and screwed a replacement plastic window frame into it. Each broken piece has half a screw hole.
2. The broken cill is 3' 6" wide and its window opening in a solid wall is 3'. As mentioned, my new window opening is 2' 6" on the outside and the extra width needed for the cill at either end is a half a brick, so I need a cill 3' 3" wide. Unfortunately the break is 1' from one end.
Can stone cills be repaired? And is it worth trying to repair and shorten this cill? It might be that it is shaped at both ends specifically for a 3' opening.
