I had a new wooden door fitted in November last year to replace the PVC door that was fitted before I moved in. Since then I've been having a few problems with it, the main one being the paintwork splitting all along the trim joins, which has been getting worse as its gotten hotter. You can also see in one of the pictures below that the actual joints between staves is starting to split.
I've got a couple of questions:
1. Is this sort of deterioration expected with wood movement or has their been an issue with manufacturing the door?
2. I am going to get the whole door repainted as it looks a mess (along with a few other areas bodged up) - is it a simple case of sanding down all the split paint and repainting, or should I caulk the joints before painting.
Appreciate any advice.
