MatthewC
- Central/South England
The renovation of our seven sash windows is not high on my list of priorities, considering the overall state of the place (see my blog at http://houseintheenchantedforest.blogspot.com/).
However, in removing sodden unattached plaster from a bedroom wall, I uncovered an interesting "feature" of a sash window which is causing me some concern. I've read a fair bit (here and elsewhere) about renovating sash windows and this normally says that it is actually quite easy as you just have to remove the wood on the inside face of the window frame which gives access to the sash weights and allows removal of the windows etc.
This looks like a fairly normal sash window and the inner faces of the side members are about half an inch thick, one piece top to bottom.
I had expected that there would be an enclosed box for the weights on either side of the frame but what I found was that there does not appear to be any side to the window frame (i.e.the side buried in the wall), so my expected box has only three wooden sides. Here's the gap on the right hand edge and the visible lead weight (with broken cord). Somehow the previous plaster was only done to the edge of the frame and did not fill the cavity for the weights.View attachment 1 So, if we manage to replaster in the same way (i.e. without interfering with the cavity for the weights), how will I (at later date) remove the windows to do the cords and repaint them? Is it really wise to remove the aforesaid complete inside face on each side? This appears to me likely to do significant damage to the material and possibly give me a window in a dangerous structural state .
Advice please! Is this normal and I am worrying needlessly? Since we are now plastering, this is now fairly urgent.
