Hi all!
I've recently purchased a 'project' Norfolk timber framed farmhouse! This is my first major period project so please excuse my lack of knowledge; I'm learning as I go along! The house has had lots of money spent over the last 50 years, but not often the right things have been done to protect the structure! The house is structurally very sound, but has been 'let go' over the past 25 years and requires completely modernising!
I have two good builders, neither are specialists with timber framed buildings, but both I've worked with before and i can trust. It's important to me however, that all stages of this restoration are done properly and in keeping with traditional building techniques.
Now, apart from making sure the building is watertight (the roof needs some small repairs), what would be the general 'first steps' on renovating a timber framed building?
My plan is to remove plaster and any modern addition (fireplaces,etc), revealing all timbers, wattle & daub and other original features, room-by-room and repairing like-for-like materials then re-plaster in lime based plaster. I am going to leave stripping external cement render for spring/summer next year. I want to reveal a lot of the internal timbers and from reading posts on this forum, it is common to insulate the building externally within stud between render and original timber? Am I wasting my time and money making the inside look nice only to risk movement and cracking in the plaster when I strip and replace the external cement render next year?
Upstairs arrangement does also not suit modern living, so I again, strip everything down, repairing timber where required and rearrange living arrangement where timber structure allows??
This may sound like common sense steps to most and I'm sure my builders have their plans, I'm just paranoid that the job's done properly with the proper materials!
Your advice would be very much appreciated, but I'm really only looking for reassurance or redirection!!
Expect many other questions and pictures with each stage of ths project!
Regards,
Dan
Regards,
Dan
