Ushy M
- South Northants
Hello folks, I posted on this subject some time time ago and got some useful advice - we've finally got around to doing something about it. We have a 350 year old stone and thatch house, with the gable end in the churchyard. The ground levels are, for obvious reasons higher on the churchard side and we've been advised to dig a French drain to equalise this. Having had an exploratory dig, we've found that someone has already dug a drain which goes down to the foundation stones. They appear to have applied bitumen paint to the house wall at sometime in the past and have filled the drain with common half bricks (which are damp).
The bitumen coating is peeling away and we think pointless to try and remove?
The external house wall appears pretty dry, there is however, no land drain under the rubble filling and we intend to install one as much to allow air in through the bottom as to channel water away. We can lead this away to a clear exit point. We've been advised by a groundworks contractor that the rubble or some 20mm shingle would be an adequate filling (tho we think cobbles might be better). The earth side of the hole is lined with geotex, which seems to be doing its job OK.
Inside the house, the wall has been replastered with modern gypsum, which we'll remove and allow to breathe before replastering with lime. Grateful for any views as to whether this seems like a good plan - and whether anyone has any better ideas?
