Nigel Watts
- London N7
I have just spent many hours rendering a small length of garden wall. Initially I had terrible problems getting my NHL 3.5 lime mix to stick to the underlying render layer which I think must have been sand and cement. By Saturday evening I eventually got all the render on and put in my fake ashlar lines.
The next morning I looked at my handiwork as was not happy. The render was far from flat and the ashlar lines only drew more attention to this fact. I had been using a cross grained float try to get a flat surface but it had not been enough. I then spent the bast part of Sunday morning correcting the problem. I achieved a much flatter surface but only through much work and constant checking with a straight edge and spirit level, again using the cross grained float to distribute the render after it had dried a little. When I put in the ashlar lines I noticed that some parts were still slightly concave, so some further adjustment was made. When cleaning my tools I noticed that my wooden floats were badly warped - the cross grained one especially was quite convex.
This experience has made me wonder how professionals seem to manage to achieve a good flat finish in so much less time.
My hypothesis is that I was trying to do too many things the same time, namely getting the render to stick, getting it flat/vertical and achieving a good surface finish and that I should have done the work in two or even three separate coats. For the next section of wall, where I have not had the same problem with adhesion, I have applied an initial coat and focused on getting this fairly true. I have also planed my floats to remove the distortion.
