Morning all,
In short I have begun to remove the cracking render from 2 external walls. There used to be a chimney many years ago on this end of the house and a flower bed up against the external wall (I removed this as soon as we moved in!)
The cracking render is a mix of lime (hooray!) but it has been heavily patched with cement, sand & cement to fill the cracks, horrible pink plaster etc etc. All of which has been painted with modern paints not limewash.I could smell the damp when I began to remove the existing render. Trouble is due to its strength it pulls varying amounts of the wall with it when remove even when done very slowly and carefully.
We have some damp showing internally on the lower walls and on the remaining hearth stone.
My biggest fear are the cracks in the cob that I uncovered (some 3-4 inches deep and wide) thus I have taken an extended tea break whilst I seek futher advice. I am guessing that with the wrong render and paint the wall is trying to breath but forcing any moisture to the internal walls and thus showing as damp internally because it cannot escape through the external wall?
Slate tiles added to the base of the wall also appear an odd addition - unsure how long they have been in situ for, should I remove or leave well alone? They have been put all the way around the house.
Really I would like to know -
1. Should I hack off both walls completely including the slate tiles, fill and limewash until next Spring?
2. Hack off and repair cracks as I go then limewash and re render over the coming weeks?
I have done some reserach around use of cob tiles and stitching the wall but unsure if the wall in question requires this or more or indeed less - if less how should the cracks be repaired or filled?
The internal wall at 1st floor level has been fully re lime plastered as we discovered exposed lathes and cob there also when doing the internal works.
Any help or advice on materials, techniques etc would be gratefully received.
I am off to the lime centre later today ((hxxp: www. thelimecentre. co. uk/) to get their advice and begin to look at materials.
(Tried to add photos but thier appears to be a ltd file size on this forum?)
Regards and thanks
Churchy
Regards and thanks
Churchy
