paulb33
- Penarth, Vale of Glamorgan
Me again. Poking around the gable today.
So, the previous owners hacked off the roughcast render before fixing plastic to the gable. Pictures attached.
Any ideas on what to re-render this with?
Elsewhere, it looks like an early cement render on a metal mesh lattice (imprint can be seen on the timbers), with a top layer of embedded small stones. It appears to have been painted with a yellow/beige chalky paint (perhaps lime wash?). Most of the render that remains elsewhere is fairly sound but now covered in modern weather shield paint.
I spoke with Ty Mawr and they say what's most important is use of a flexible board substrate to allow for movement. They were less clear on the merits of a lime render. I assume breathability isn't a huge issue here. But, movement and frost damage might be. I may also need to render in the winter, which may be a factor when using lime. Most important for me is not having to re-render in 5 years time! It seems I will need to render the entire gable from the second floor to the apex.
Value folks' suggestions on this.
Regards,
Paul
Regards,
Paul
