Gervase
- North London
A new project has lovely matchboard walls, ledge and brace doors, built-in dressers and lots of moulding; all liberally coated with thick, treacly coats of Sadolin.
What's the best way to remove the stuff? Heat, chemicals, scraping and abrasion...?
All the woodwork will eventually be painted rather than stripped, so I'm not worried about any staining - just getting it off the surface. There's quite an acreage, so using Klingstrip or a similar water-based poultice, with the accompanying mess when you wash the stuff off, probably isn't an option.
And then there's the roof to worry about - the place was built (or extended upwards) with wrinkly tin, but the client is set on slate. Tin is the most authentic covering, and will allow him to use the existing roof structure, with just some purlin ends needing replacing, whereas slate will entail an entirely new roof and wall-tops to take the additional weight
He's probably prepared to pay the hefty premium for slate, but there are so few tin roofs left now that the pedantic part of me would like to see this place kept as tin. It's one of those issues where perhaps greater diplomacy than mine is required! Anyone got any links to some nice corrugated iron roofs that I could show him?
