Geoff Pritchard
I want to remove hard cement concrete render from the walls of a cellar in an 18th Century town house because this has acted as tanking and is driving moisture up to the room above causing salt tidemarks as the moisture dries out depending on room temperature. I wondered if anyone has any tips on removal of cement render without damaging the lime mortared brickwork behind. If I hacked off some of the cement without taking it all off would it allow the wall to dry out sufficiently through evaporation into the cellar or would I need to take it all off ? I am worried about damaging the foundations behind. Any suggestions gratefully received. Thanks. Geoff
