A
Anonymous
Guest
I'm currently in the process of removing an old fireplace. The problem I have is that having stripped everything away, I am left with the original fireback/insert and the fire grate (which, incidentally appear inseparable). It seems to be fixed in with concrete around the top but there are gaps at either side (the fireback looks much the same as the illustration near the bottom of the page in the attached link). What would be the easiest/best way of removing this fireback? There is also a redundant back boiler which I would need to remove. Any suggestions on how to go about doing this would also be greatly appreciated. Thanks.
http://www.c20fires.co.uk/fireplace_fitting.htm
