have posted in past due to damp problems: 1860's stone built end terrace built into hillside up to top of livingroom ceiling at back of house. Public steps come down gable end of house and there is a road immediately adjacent to house at back. Property renovated in 60's by council which was probably when cavity walls added along back and gable walls on ground floor and there is some sort of dpm between in the cavity wall below floor level, so in theory no damp should be present. Scottish lime centre came down for a look and confirmed cavity walls etc all built correctly but didn't look in cavity walls. Removed a brick at weekend (plaster not very hard to get off!) and a fair build up of sand inside cavity, probably up to level of top of skirting board along wall, and silted up beside chimney breast and at corner of gable/back wall, where plaster most damaged. The outside wall feels damp to touch but fully expect that as built into ground. The sand itself feels a bit damp, bricks feel ok, but it's been dry for a good 2 or 3 weeks here. So, I am quite pleased about this as it was the result I was hoping for as debris can be removed and bricks/replastering assessed. My question is should we add some airbricks at skirting level when we have let it dry out etc. There is one vent in that area at the top of livingroom wall that vents through to the outside at the moment. I feel it could benefit from added ventilation but worried it may increase condensation in the cavity in colder months.
