A
Anonymous
Guest
Hi, I am currently trying to fit a multifuel stove and have been advised to fit a 6 inch steel liner to the chimney - unfortunately on inspection the top 4-5 feet of the chimney has been lined with a slightly damaged clay flue liner which is too narrow to get the new flue through - Is it possible to remove this without removing and subsequently rebuilding the chimney stack? So far I have tried hammering away at it with a long sharpened metal rod - but it is painfully slow work! Thanks.
