Hiya
We own an old chapel, which at some point in its history has been rendered with sand:cement, to improve the weathering as the bricks are very soft. We now want to remove this and re-render using lime. (unfortunately can't expose the brick as it has been badly keyed)
We're in the process of hacking off the two coat cement render - does anyone know how fastidious we need to be with this. The base coat of the render is extremely hard to get off without damaging the brick, and we're not sure if we need to go back to bare brick, or just to a sound surface. I know lime render allows expansion / movement and that cement render doesn't, so wasn't sure if having some cement render under the lime render would make it fail?
Any thoughts
Cheers
Suzy
Any thoughts
Cheers
Suzy
