Hi
I have a 1790s Grade II cottage. The bedroom ceilings are low and not straight. One bedroom ceiling was starting to come down - so I dismantled it before it fell. Now its all exposed I'm thinking I might try and leave it that way - looks nice. I've reached out to the CO and asked their advice on my plans before filling in another LBC application form (the last one took 7 months to get processed and approved
- not sure my teenage daughter, who's bedroom is most impacted, is going to wait that long). Worse case I could simply whack up new plasterboard and effect a repair and move on if I don't get permission.
The current configuration - walls rise up 2 feet from floor with exposed studs and wall plate infilled with plasterboard. Then plasterboard between the rafters so they are exposed and that slope in and rise to a height of about 6 feet and to the plasterboard ceiling suspended on ceiling joists. Above the ceiling the rafters continue to rise up a further 4 feet until the ridge beam - so in other words a small loft space above the ceilings - I don't use any of it for storage - just water tanks above the bathroom. Most rooms run in series i.e. long thin house.
Options I am considering:
1. Just use the same type of insulation (glass fibre between the roofing liner) and continue with infill plasterboard close to the ridge beam and infill panels either end of the room to close them off from the neighbouring room. This would leave the ceiling joists exposed - I call them ceiling joists because the current ceiling are attached to them - but really I should probably call them collars - which is what I think their original purpose was.
2. Would I be better using lath between the rafters rather than plasterboard and then use lime plaster. My preference would be to use something like wool for insulation because it is light and flexible and less nasty than fibre glass and easier to shape around the irregular rafters than kinspan. But I'm worried all that oak lath up in the attic would cause the rafters to sag (even more). Secondly I'm worried that the fact the rafters are at an angle i.e. not vertical studs! that when I come to plaster them the plaster wont form good nibs because the insulation effectively laying on the laths.
3. If I did go for lath and lime up in the rafters should I remove all the existing plasterboard and lath and lime it all down to the wall plate. Or should I try and install some kind of edging plate and leave the existing plasterboard intact below that edging plate and use lime and lath above. i.e. this would be an edging plate between each rafter and at the height of the existing ceiling.
As I say I have outlined my plans and options to the CO, but I'd like to get a view of what others have seen, done, recommend.
Thanks,
Dave
Thanks,
Dave
