sarahj
- northumberland
Hi there,
We are just about finishing removing the cement plaster (four inches in parts!) from a three foot thick stone and rubble wall. It was damp for up to three feet up, and the skirting was rotten, and the furniture had begun to mildew. We have been in the cottage for just over two years and had installed a wood burning stove in this room at the same time.
Horror of horrors, it seems that the wall finishes above the floor, and that the wall is built on sandstaone which has now turned to damp sand. in some places the (very old) concrete floor is only an inch thick. Some of the sandstones in the bottom of the wall have disintegrated completely and disappeared with the plaster. Most of the stone for this house and this wall is not sandstaone and has not been affected.
We are on the side of a hill, and digging in the garden has unearthed sa ndstone bedrock, so I think this is what our cottage is built on. We are just belwo a very old mott and bailey castle and this mound that we are on has unnumbered active springs all over the place. Next door has a well.
This cottage was once a one up one down and built as a 170 year old granny annexe onto the big house next door. They have no damp problems. this wall used to be an outside wall onto a yard. The extension was taken across the yard and joined to a 15ft (original) stone retaining wall. I think it will always have had damp but we need to domething about it if the stones are rotting?
And I think this might mean the floor should be raised (although it isn't below ground level at the front or side). What might the CO suggest? I hope it won't be expensive or complicated as we had thought that just repointing/plastering in lime with the possibility of a limecrete floor soetime in the future was all that was required - we replaced the disintegrating plastic guttering and cement pointing when we moved in - but now I'm starting to panic!
Sarah
Sarah
