pianoredwood73
- Devon
Hi everyone, sorry in advance this is long...
OK, 15thC thatched cob/brick/stone house in Devon. Nastily done in the 1960s-80s.
We've made a start in one bedroom by stripping off the lining paper which covers every internal surface of the house. The vast majority of ceiling and walls are lime plaster which looks sound and very good, better than feared. Ceiling is very billowy in places but looks fab and doesn't appear to be about to fall down despite quite a few cracks...should we be filling these cracks or skimming over with a new coat of lime plaster before limewashing? Is there a way of helping it key better in those areas? Do we just wait and see if it falls down?!! (Got a 3 yr old and new baby due in a few months so obviously can't risk their ceilings collapsing - these also currently have lining paper and are very billowy as well, need advice on that).
Main qu though was: there are a few areas of max one or two m2 which have been patched with cement/gypsum plaster, very hard, mainly around windows (walls are very thick, reveals are therefore the same) and there are cracks where the gypsum meets the lime. Initial thought was hoof it all out and build it up again with lime - however, we think in many of these areas the original lime will come away to a degree, esp on the ceiling around the sloping bit which runs down to the top of the windows.
So should we leave well alone as now 95% of the room can breathe (plan to replace external render with lime as soon as funds permit as well), or go ahead and get rid of all offending material and run the risk of having a fair bit fall off and be lost ie far more work/money but more purist?
Any advice gratefully received. Finally, advice on appropriate finish which won't rub off on clothes? All will need to be applied to every room in the house so we want to get the process right at this stage...
Many thanks if you got this far!
Sarah
Sarah
