citizensmith
- Herefordshire
I want to know if there are any obvious pitfalls if we take this course of action.
We need to extend our heating system to the top floor and our 110,000 btu boiler of 15-20 years age is not going to cope with 4 receptions, kitchen, washhouse/utility, bathrooms, and 6 bedrooms (probably 150,000 btu + needed.
The current boiler is in the washouse which is a long way from the main house and pipes are fed through the washouse roof and breakfastroom roof
until they get to the main house. We may wish to turn the washouse into a living area or large kitchen at some stage (years away).
Under the main house is a 32ft x 12ft two compartment partially vaulted cellar. The cellar ceiling is about 70/80cm above ground level (so could accomodate a balanced flue).
My main question is that if a boiler is installed it will change the environment of the cellar - drying/warming the air. Will this be a benefit? or will joists/beams etc suffer unforseen damage due to the change in microclimate after 200 years of cool/dampish conditions? We have a bit of a woodworm/deathwatch issue down there and i wonder if lowering humidity would actually help? Thanks in advance for any replies!
