tobydog
- South Suffolk
Ever since we moved in we have had a problem with damp in our side utility. You can't see it inside but you can definitely smell it. The bricks in one corner on the outside are damp but there was no obvious reason why. I recently started taking the bitumen coating off the wall thinking that it might help and I realised that the single skin wall only goes 2 brick courses into the ground at most. In the first picture below you can just about see the brick plinth below the power cable. I have poked around directly under the plinth and there is nothing else supporting it.
At first I thought that ground/rain water was finding its way easily under the plinth until I came across the bottom of a redundant downpipe. The odd thing it that this downpipe is 5" diameter compared to the functioning standard downpipe at the other end. The redundant pipe was full of earth but just 6" in the soil became very soggy. I've traced the angle of the pipe back to a main drain in the drive. For some reason we have another in-line inspection hatch in the drive which is a single drain with a bend. I would have thought the main drain cover would have had to come off off when the extension was done in 2010 but it looks well sealed down. The builders tapped into the existing waste pipe from the house so maybe they didn't open it.
I think that this main drain will have a redundant pipe heading from the side utility that backs up with water if it is overloaded and that this pipe must have a leak somewhere. Does this make sense?
Dumb question alert as I've not worked on drains before. Is there any reason why I can't lift the main drain cover and check? Are the airtight? If I get in, is there a way of capping off the link from inside the inspection chamber?
