Penners
- Suffolk, England
I'd welcome anyone's views on the following, please.
Mrs P has a small studio (she's an artist, and a pretty good one), which is actually a lean-to extension to our Georgian brick cottage. It has three exterior, single-skin, 9-inch, brick walls.
The studio has no central heating, but it has a wall-mounted electric convection heater, which is kept on at a low level throughout the winter months. Despite this, the room suffers from humidity problems, so we also have a fairly good quality dehumidifier in there.
In spite of all these precautions, the room has developed black mould spots on the walls behind bits of furniture and in the "dead-air" corners, caused no doubt by condensation. This is bad news for Mrs P, who suffers from an asthmatic reaction to mould.
In order to try and resolve these problems, I plan to line the interior walls with insulated plasterboard, and fit the room with a humidistat-controlled extractor fan, in addition to the convection heater. As I mentioned above, the room is already very small (2.2m x 1.7m), so I want to minimise the loss of space that this interior lining will inevitably cause. Do you think I could get away with installing the insulation-backed plasterboard by gluing it to the brick walls, or do you think it's essential that I batten the walls first, in order to create an air-gap between the bricks and the plasterboard's insulation backing?
Incidentally, the ceiling is quite well insulated, with about 250mm of rockwool between the plasterboard and the sarking felt. The roof is single pitch pantiles.
Any thoughts and/or advice gratefully received.
