I have a beam which is currently painted in a water based black paint. Underneath the paint the beam is in a very poor condition. Although the core of the beam remains (and remains structurally sound) there is a 20mm depth all around this core that has suffered significantly from woodworm and possibly DWB attack.
The other beam in this room had to be replaced (with reclaimed beam) as the damage to that beam was beyond repair (the beam having lost about 60% of it's depth due to insect attack).
I need as far as possible to bring some consistency to both beams in the room.
I was thinking of the following approach:
1. Remove paint from painted beam with Klingstrip to determine exact condition of beam.
and then either:
2. Sandblast beam - not my preferred approach as I suspect it will leave the beam very pitted and cause too much damage.
2. Remove by hand the loose material (hand sanding) and leave natural wood exposed.
2. Sand with machine to sound material and leave exposed.
3. Treat both beams with either a limewash to scare off the wee pesties or a raw linseed oil.
Your comments or experiences of similar would be greatly appreciated.
and then either:
