keithevans595
Last year with advice from this forum I had part of a downstairs room replastered with lime putty plaster and solo lime plaster supplied by the Lime Centre.
It was left to dry out and painted with Earth born paints, in particular the feature wall is a dark green and the other walls a light green.
All was well, but a month or so later random patches of the feature wall, dark green, started to show darker patches like they were damp.
I thought they may sort themselves out over the hot summer but not so.
I have tried playing a gentle heat from a fan heater on them and they do begin to fade, but as the surface cools down they reappear.
One possible reason for the "damp" patches maybe that I blended in the new plaster to the old plaster with a very thin layer, max 1mm, of normal filler and filled in slight dips.
This may be why the patches are so random over the wall.
I think the only solution, and yes, I should have done in the first place, is to rub down the patches to get rid of the filler and apply a breathable filler.
Which brings me to my question, what breathable filler would you recommend?
Thanks in advance.
Thanks in advance.
