Black Timber
New Member
Hi all
I bought some 24x14 slates for a repair. They mostly already have four holes. Are they still ok to re-use? I know I have to make new holes when fitting them.
Just to add, the new holes will be lower as they're going on a roof with 20x12s. I'm just using these at the abutment, where I'll cut them down to 20" in length, but needed the 2 extra inches to reach the wall. They are a bit thicker mind, but being at the end I'm hoping they'll be ok (unless anyone thinks otherwise?).
There's also one slate with a diagonal crack/line visible on both sides. It rings ok when tapped and seems sound. Is it ok to use?
Speaking of ringing, one clearly rattles when tapped, so won't use that. The rest do ring and reverberate in the hand, but it's quite a low ring. I've got other slates from another yard that ring higher and longer. Is that normal?
A link to some photos:
Many thanks
Slates 2023 – Google Drive
drive.google.com
Many thanks
