paulb33
- Penarth, Vale of Glamorgan
Sorry for the lengthy post. Folks have been kind in responding to numerous posts about our restoration. Well, our 1901 arts & crafts house is now shrouded in a ruinous quantity of scaffold. I stood next to the chimney-stack yesterday. Weird how this was so thrilling. I must get out more….
Anyhow, I'm puzzling about rebuild of the main stack. I only have the original architect's watercolours to go on. Also, the size of the base that remains.
I've attached a draft scale drawing of the stack that an architect knocked up a few years ago. Also, a photo of the chimney stack base and the original architect's drawing (showing the stack in all its glory).
The restored chimney will likely consist of two 2240mm tall offset square stacks made of imperial (230mm x 73mm) bricks standing on a 1300mm x 800mm limestone base. This limestone base will sit on the 1165mm x 675mm imperial brick base that is currently in situ and capped at second floor level. The chimney would be visible from the road as two diamond shaped brick stacks.
One thing is puzzling me and the drawing doesn't address it: how doed the two stacks sit or tie together?
The size of the base (1165mm x 675) means that two stacks made of two imperial brick widths (230mm x 73mm) with 5mm mortar would be too wide for the underlying brick base that still remains. So, I've concluded that the stacks must probably interlock somehow. But, I can't for the life of me work out how the brick interlocking between the tacks would work and ensure bonding. I've even made paper bricks to model this bonding, but without success. There's always two mortar joints lining up on adjacent courses. Doubtless I'm missing something very straightforward.
Perhaps cut-down bricks are used? But, that wouldn't seem a very elegant solution for stacks that are clearly two brick lengths in size.
Who has the brainpower/brick experience/patience and is kind enough to help to solve this riddle?
Regards,
Paul
Regards,
Paul
