malcolm
& Clementine the cat
- Bedfordshire
I have a garden wall which I'm guessing was built before 1850 (given the way it forms part of the gable wall construction of the 1850 barn). It is mentioned in the conservation area appraisal document as an important wall.
It is a retaining wall (we are 6 inches or so higher on our side) and someone planted a huge conifer beside it so it leans a lot. We have cut the conifer down and I don't think the wall is in danger of imminent collapse, but there is a footpath on the other side and I don't fancy the risk of prosecution if we get strong winds and I squash someone. The bricks are soft reds and have spalled badly, but mortar is mostly lime so it ought to be possible to salvage bricks.
I would like to rebuild the wall, hopefully using the original bricks turned around and fill in the gaps with reclaimed bricks, all lime mortared. I am keen to increase the height by 2 bricks to match the fence which would make it about 1.3m high.
My reading of the planning laws is planning is only needed if the wall is over 1.8m. In a conservation area planning is only needed if the change will affect the appearance of the conservation area. I reckon I'm good for both. Is that a good reading of the rules? I could apply but judging by the neighbours wall from hell planning experience it will delay the fix until next year so I'd need to do something naughty to prop the wall up on the side I don't own.
Any ideas for what would be the least naughty fix? Retrospective planning if they need it maybe?
