Hi
I really have struggled to find anyone to come out to my little cottage and conduct an inspection on three areas of damp in my lounge.
The house was built in the 1700s, timber framed and alas has a concrete floor in the lounge. I rent this property out, and when some tenants moved out 2 years ago i noticed a damp patch on the wall where they had had their sofa and two other areas where peices of furniture had stood. I assumed condensation as it didnt look as if the windows had been opened in a long time. The last lot of tenants have moved out and the patch behind the sofa (internal wall between kitchen and lounge) has grown dramatically in size. The other two patches look the same (one external wall, one internal between bathroom and lounge). I took up the carpet and the underlay was sodden in a balloon shape stretching out from the kitchen door (next to the wall with the large damp patch), the carpet was dry as was the floor. I put plastic over the lounge concrete floor and taped it there and the next time i visited there was no damp on it at all. I concluded that there mustve been some plumbing or kitchen disaster that was unreported to me causing the underlay to act like a sponge and be sodden. Plumbing checked, all OK, no underfloor pipes in the lounge or kitchen at all.
The one and only company i found to come out to inspect the damp and sent me their report and state 'rising damp' to all external and internal walls, and suggest a chemical DPC to the external lounge wall and the opposite internal wall, nowhere else. The recommend replacing the plaster up to 300mm on most walls in the lounge, part of dining room, bathroom.
Oddly they make no note of what the large damp patch behind the sofa is caused by and also state the building is 'mainly of traditional brick construction'....i wouldve thought the exposed beams may have given the game away on that one!
Now i dont know what to do. After removing the damp underlay and the carpet and letting the place air for a week i noticed the large damp patch behind the sofa had started to 'dry' back at the top by about 2cm. I have a new tenant moving in shortly who is aware of the damp patches.
Any advise on what to do, i maintain the larger patch is condensation either caused by living habits, air getting trapped in combination with the kitchen plumbing disaster which the underlay soaked up.
Not sure what the other two patches are and what can be done about them.
HAve no faith in the inspection report whatsoever. And no other damp specialist is interested in coming out to inspect.
Help!
Help!
