A
Anonymous
Guest
Hi
I am a joiner and agree with david penrose.
when I fit skirtings to curved bays I use the method of cutting slits in the reverse of the board as deep as i can getaway with (just over two thirds of the thickness) the skirting should be quite floppy and great care should be taken in supporting it whilst moving it to the location your going to fit it to. just perious to the next stage you should apply grippfill to the wall to skirting in place ( if your wall is dusty cote with pva and let it fully dry ) then I lay in face side down dampen each slit with cold water and squirt adhesive (it is very important that you use a pu adhesive not pva) along each slit ( this adhesive slowly expands when in contact with water and dries waterproof ) at this stage lift the board so it is facing you and slowly push the board into position following the contours of the wall this should not be difficult if your cuts are deep and close together. you should now use a length of board to hold each end of the skirting into position fix though this board into each and of the skirting and leave over night. the adhesive you have sqirted along each slit will now expand and bond each slit together preventing it from trying to straighten itself. the skirting does not require any further fixing and if you are going to varnish the skirting use a 2 pack filler the same colour to fill any holes. I hope this is of use to you there is another method but it is not for the DIY person and too drawn out to put into words. you could always contact a good chippy who would di it for you.
this method is my own and is something I discoverd when fitting out a cruise liner. p.s. the glue I use is Bonda PU power adhesive if you need any more help contact me
