malcolm
& Clementine the cat
- Bedfordshire
I'm planning to get some people in to do the exterior of my house next year. I want to get scaffolding up, fix the roof and guttering, remove the paint from the exterior, and fix the external wood frame and windows.
For the roof we have small plain tiles at the front and slate at the rear (the pitches are different). I think it was put on in 1910 - there is no vapour membrane or eaves or ridge ventilation.
The small plain tiles on the front roof are missing many of their fixings and they are slipping. There are leaks where tiles or batons are missing, and around the leading (or possibly cement work) on the high part of one of the chimneys. I think the tiles need to be lifted, batons replaced, badly fitted skylight fixed, tiles re-fixed, and flashing sorted on chimneys. Here is a picture.
I had been thinking about a vapour permeable membrane just for the sake of catching any wind blown drips, and that would require eaves ventilation.
The slate roof at the rear isn't causing any problems at the moment. The surveyor mentioned some of the tiles had started to de-laminate, and some have been replaced to the right of the photo below hung on metal clips. Here is a photo:
We spoke to the roofer about lifting and replacing the slates when we were up there and getting the whole house fitted with a membrane. He said half the slates would be broken, new ones wouldn't match, and we would be better off fitting new. I think this is where most of the cost in his whopping 20K quote is.
I'm leaning towards getting only the plain tiles at the front lifted and replaced, fit a membrane and eaves ventilation at the front. Leave the slates at the rear for a few years until they start to cause trouble, and use the ventilation from lack of vapour barrier at the rear as an alternative to ridge ventilation.
I've not checked whether building regs actually require a membrane. Thinking about it there is no need to really have one. 100 years after being botched into place the roof still works, and leaks on the ceilings do encourage timely repairs.
Does that sound sensible or would you do something different? We'll get some more quotes too.
