Hello,
I am in the final stages of buying an Edwardian end-terrace property and this website has been an excellent resource to help me understand the original features and building technique so, thank you!
The property is in need of attention in all aspects, but foremost it needs re-pointing. From reading articles on this website and others, I gather that lime mortar is recommended to act as a sacrificial, breathable layer between the bricks (in this case, Accrington bricks). I think it's quite likely the property has been re-pointed with cement based mortar in different places at different times, which worries me because I've read that cement based mortars can cause damp problems in these types of properties due to acting as a water repellent barrier and increasing the rate of freeze-thaw degradation in the bricks.
So, should I be considering removing all traces of cement based mortar before re-pointing using lime?
