cheadle123
Can anyone help? I am new to the forum and have little to no knowledge of masonry repairs.
I live in an 1850’s (Victorian) cottage in Chester which in 2003 and was both extended and re-pointed in the original “Cheshire” brick. I have noticed on my south facing wall that the mortar below the backdoor threshold has totally decayed / crumbled. It appears that the mortar that has crumbled is below the PVC damp sheet but in a few areas it appears the mortar above the PVC membrane is wet.
How can I repair this issue? Is it normal for the mortar to decay below the damp proof PVC Membrane line?
I guess with the house being so old the mortar is a lime mix? If so, what does this mean about the condition of the foundations?
Just for the sake of clarity. Given the house age of 150 years and therefore I think lime mortar has been used, does this mean the foundation mortar is decayed / crumbled? What sort of foundations did houses of this age get built on? Should I be concerned?
I noticed that the builder in 2003 re-pointed the house in a cement mix (I guess over the original lime mortar) and spray coated the brick with clear sealant (but has added breathe holes / grids at the footings).
I have not noticed any crack / subsidence but when I went to mount and external light about half way up the wall when I drilled into the mortar it was very easy (not damp) unlike when you drill cement mortar it is harder to drill. Is this because the mortar is a lime mix and therefore easy to drill?
What signs should I look for by way of damage with regard to the builder in 2003 re-pointed the house in a cement mix (I guess over the original lime mortar) and spray coating the brick with clear sealant ?
Any help / advice truly appreciated.
