We are about to site a range cooker partially inside a large stone fireplace and I am trying to decide what to do with the back (and sides) of the fireplace opening. This is the only place to put the cooker in our two bedroom cottage, however in the future we plan to have more living space (repair falling down building attached) in which case we may move the kitchen somewhere else and put a wood-burning stove in the fireplace instead – I would like to retain the flexibility to do this.
The back of the fireplace is a stone wall, which we have tidied up in some areas with lime mortar. There is heavy staining of the stones with soot in some areas. The options are:
1. Leave it exactly as it is. Some people would turn their nose up at the rather poor quality of the stonework and the soot staining, but I really don’t mind this – it is what it is. My concerns with this are practical as I assume that it would be difficult to clean the stone when over time grease from cooking accumulates on the surface.
2. Cover the back with lime plaster, and then limewash in white or a beautiful colour. Again not sure that this would be a cleanable surface. Could just apply another coat of limewash from time to time, but not sure this would work too well over e.g. a heavy grease stain. Or could paint the lime plaster with a washable paint (not breathable but then difficult to get the surface to be washable and breathable).
3. Cover the back with lime plaster and then cover with tiles (easy to clean) – not too keen on this option as I am trying to keep the look as plain and simple as possible and concerned that the tiles could attract attention away from the real stars of the show – the stone fireplace and range cooker.
4. Dry board the back and then cover the dry board surface with paint/plaster or tiles. This would make it very easy to revert back to the original stone at the back of the fireplace at a future date. Are there any issues with dampness building up behind the dry boarding? (I say that because when we moved in we ripped out all the dry boarding in the rooms downstairs, which was rotten, and now the place is much drier. However a lot has changed since then including removal of the leaking immersion heater…)
So my questions are:
1. Am I over-worrying about having a washable surface behind the cooker. (We don’t do a lot of frying, and the distance between the back of the cooker and the rear of the fireplace will be at least 30cm).
2. If we lime plastered the back of the fireplace then how much of a pain would it be if we then at some future date we wanted to remove the lime plaster and return to a stone wall. If the answer is that it would be relatively easy then will probably go for option 2.
In terms of the solid stone sides of the fireplace (which would be approx 20 cm away from the side of the cooker) we could:
1. Leave as is. (Could occasionally give it a quick scrub down as easier to reach than the back of the fireplace).
2. Try limewashing (but the heavy soot staining of the stone underneath would then also end up staining the limewash).
3. Try covering with some other (removable) surface?
