Wesleycottage
Ammended
Please can any one advise?
We have recently moved into a Victorian House. I have been sorting out some bits. One of which was the cause of damp to an external wall. i traced it back to a leaking /blocked down pipe. this is now sorted, however.....
The down pipe went to a brick hopper and into a cast iron bellow ground pipe. This ran along a party garden wall and left the property just bellow ground level through the foundations of the brick wall at the front of the property (with me so far?) directly into the ground bellow the footpath.
The path that this cast iron pipe originally took is now blocked by:
BT have inserted a telegraph pole directly the other side of the wall, butting up to my wall, and in direct line of the iron pipe, which must have ran into the sewer under the road.
Do I have any come back on BT or the highways to reinstate the drain? There is no room for a soakaway, what else can I do? The water currently drains onto the soil at the base of the downpipe.....
Jim :?
Jim :?
