We had the 1750's house's gable end of rubble-filled solid stone walls repointed last year. The mortar used was cement/lime/sand. The chimney stack was rebuilt. At the same time chimneys were relined - two with SS liners and one with clay pipe. The areas inside that needed replastering after breaking into the chimney flues were replastered with "good old" gypsum onto the stone. Lime plaster we think lies on each side of the gypsum areas. Guttering seems fine and roof space is dry. Damp/wet areas of internal walls match exposed areas of external wall - we are semi-detached to a lower house and the external wall protected by their roof and rooms is not effected.
The wall faces into the prevailing wind which has been laden with rain for the past few weeks. We rapidly noticed that the plaster inside was lifting off the wall, cracking, squelching and water dribbling.
Areas which didn't lift have become damp and mouldy. Paint has blistered. The gypsum plaster seems to remain intact - just darkens with damp.
Is this just what happens in solid walled houses in horrendous driven rain or will the cement/lime/sand mortar have played a part? Would the house benefit from a thick lime render on that side? Should we hack out and repoint again with lime mortar? Should we replace internal gypsum with lime plaster?
Thoughts most gratefully received! :?
