88v8
- Glorious Gloucs
As a rule, the overhang of the thatch keeps the rain off the top of the house, which I guess is why I haven't noticed this before, but as I write this seated on the floor of the bedroom, a gale from the north is blowing water against the wall behind me, and along the top of the 4" elm beam level with the window sill (the one with the ugly alarm box) there is a distinct damp patch. The slight yellowing of the white paint below the beam - alas, not whitewash nor distemper but heyho - suggests that this is not a new incursion.
So, the presumed gap on the outside will have to be sheeted over and left until the wood is thoroughly dried out - some months - and then some sort of filler applied.
Resisting the temptation to reach for the sealant gun, I seek guidance on a suitable filler. The adjacent panels are wattle & daub.
In the fields that surround us on three sides there are sheep, and in my workshop there is some fresh NHL5. Does this provide appropriate ingredients, or is there some better solution?
Edit: descending to the kitchen - the windows below the top room - I find many damp beams and panels, with water runing down behind the power sockets. Hmmm. PO had the beam above the kitchen window refaced, one can see the pegs, I presume it had rotted. The whole front has a pronounced belly, so I guess there has been a history of movement and water incursion, a vicous circle that I need to interrupt. Easier said then done when the beams are damp and therefore somewhat swollen, and will therefore shrink and crack any applied filler as they dry. The joys of a period house.
