I have a small unused fireplace in a tiny unused box room in my 19th century property. It comprises of a cast iron fire surround and one of those small open or close flaps that opens up into the chimney. The problem is, when it rains, water must be coming down the chimney as there is always a damp patch on the hearth together with a layer of lime mortar dust.
When I first moved into the property a few years ago, I opened up the above chimney flap for the first time and was able to rake out a good handful of this mortar dust in addition to that which fell out into the fireplace by itself.
The chimney stack itself is about seven foot high merging upwards from one of the side walls on the building and has two chimney pots serving two similar sized fire places which are in staggered positions, one at ground level the other at 1st floor level. It’s only the upper level fire place that has this problem.
I guess there must be a degree of mortar decay on the inside of the chimney however the outside brickwork looks pretty sound and has been repointed with lime where necessary.
At the moment, I'm leaving the fireplace flap open to maintain a good airflow up the chimney and as both fireplaces are unused, I am considering adding some chimney pot covers to stop any more rain coming down. I’m not sure however if there are a variety of designs on the market that would be in keeping with my period property (a former 19th century religious Sunday school)?
Any comments/advice on the above would be appreciated.
