atlasfever
Hi folks,
I have a question about radiators and underfloor heating.
Background: Total refurb of georgian flat, including lifting floorboards, so I have the opportunity to redo piping.
1. Radiators: My biggest room is 25 feet by 16feet by (height) 12 feet with 3 large 1st floor single pane windows about 9 feet high. I used one of those BTU calculators online and somehow arrived at almost 30,000 BTUs. At the moment, each window well has one radiator (ugly, 80s version, box shaped) which would be replaced. The width of the window well is about 1 metre i think, and height before the bottom of the window is likely only 2.5 feet. So, one can not fix the largest of radiators there. An architect suggested that 3 of those small radiators would not provide enough heating in winter. The kitchen is similar to the living room, but 2 windows wide so roughly 2/3rds the width, but same dimensions for the rest.
Question:
a. If I put in those old fashioned chunky metal ones, could I get away with just doing it in each window well? or, would I need to had a row of them along one of the back walls? I am not very excited about this idea. But, if a chunky one (2.5 feet wide, 2.5 feet high) only produces like 4000 btus, then I would only have less than half of what is required.
b. I saw a chrome version of the chunky ones. WOW. But, the price made me almost cry. Maybe black gloss paint instead
2. Underfloor heating (water, not electrical): I could do this option apparently, but am concerned the new wood floor I will be adding may warp, etc. I heard some walnut floors can take the heat (special engineered boards), but does anyone have any experience with this? Maybe this is a totally crazy idea, to add underfloor heating to a period property.
What do you think folks? Keep in mind that I have decided to lay a walnut or oak on top of the orig floor boards (incidentally, not original floor anyway) and have to lift the boards so that sound dampening can be added anyway. And, I got the impression that the cost of replacing all of my radiators is not that much less than underfloor.
Thanks, A
Question:
Thanks, A
