asimon
- Sout East London
Dear Forum,
I have a property built around the 1820's, which has pebbledasing, it’s become apparent more so in the recent weather that the wall are not water tight and the pebble dashing needs to be replaced, I have received 3 quotes/estimates with quite varying prices from specialist pebble dashing companies located around the area in which I lives SE London /Surrey, I have attached the quotes and pictures of the property, I have left out he names of the companies, as I was not sure if I am allowed to mention them on the forum, details as follows:
1. £6,500.00 - This father and son company were very pleasant explained there process, even said they would replace the air bricks, and pebbledash up to 1 meter on the side return, in the quote they also mention using lime, which I see mentioned a lot with regards to doing work on period properties, the quote was type up and sent via the post, as you will see via he attachment.
2. 4,5600 - This chap came on his own, hand a quick look explained the process, and suggested where we should pebbledash up to 1 metre on to side return as above, filed in his estimate sheet there and then
3. 2,800.00 Once again this chap came round on his own, and said the same as above showed me examples of the pebbledashing, said that e will not be putting scaffolding up, as he has his one movable type scaffold, once again filed in his estimate sheet there and then, however he also gave me a list of 40 properties, that he has done work for with their full address, and type of spa that was used.
As you can see the difference in price are quite a lot, all 3 of them mention they are members of The Guild of Master Craftsmen, I have verified tis via the website.
Just wanted your thoughts opinion, as they always say the cheapest is not always the best, but don’t really want to pay £6,500 if I can afford it, even though this company was my preferred choice.
Just selected the img icon to insert the images, but it is not directing me to select the images, can anyone advise on loading them,
Regards
Allan
Regards
Allan
