somersethouse
About a year ago we lifted the old carpets and underlays in the living and dining room of our house (we suspect the house to be early Victorian but don't know the exact date). The floor underneath is of old quarry tiles (red and black chequered) and was in okay-ish condition but there were a number of missing quarry tiles (which we have replaced - laying them directly onto the sand like the others that were already in place). There was also a fair bit of crusty, white, hard build up in places (which we have scraped and cleaned off). The overall appearance of the floors is pretty good but we have had a few problems (particularly in one of the rooms - the dining room) :-
Initially, we had a very fine whitish powdery substance coming up through the tiles in one area of the dining room. It would appear daily (usually overnight, particularly if it was very cold during the night). It only came through the red tiles. I started by just sweeping it up every day but it was beginning to drive me round the bend so I experimented by coating the floor with linseed oil - this immediately solved the problem and a few months on, we have not had any sign of this white powdery stuff (phew!).
The problem that we have now is that we are getting a different kind of whitish substance forming on the top of some of the red tiles (in general it affects the tiles that run along the external walls of the room and can effect tiles up to about three or four rows from the edge. From doing as much reading up as I can, it would seem that this is caused by salts being carried through the tiles by water (which evaporates leaving the salts behind on the surface of the tiles). The coating of linseed oil has had no effect on this phenomenon. Certain tiles are badly affected and it is very unsightly (I don't mind a roughish looking floor that shows it age at all but this whitish stuff just looks very odd).
I understand that it is good for a floor like this to 'breathe' and allow water to pass up though it and evaporate but don't know how best to tackle these white marks. Is it likely to be the result of 'too much' ground moisture under the floor? The external ground level is high on the one side of the room and there is a French drain running along it (this was the only solution as it is in my neighbours garden unfortunately and as their whole garden is above the level of our house, there isn't much chance to do anything to remedy the ground level situation at the current time). The other side of the room (also currently affected by the white marks) does not have a high external ground problem (although a leaking gutter was replaced along that wall back in December and the lower half of the wall has just recently been re-pointed with lime).
I can't see much else that I can do externally to try and reduce the amount of moisture under the floor and wondered what my options are internally...? The phenomenon only affects red tiles (are black tiles less permeable\breathable?) so I wondered if replacing the affected tiles with black tiles might resolve (or mask) the problem? I could paint them with red tile paint so as to keep the pattern. I know that masking problems is not a great way to go but don't see what other options I have. Does anyone have any bright ideas or suggestions? What are peoples thoughts on laying a sheet of plastic under the affected areas? I again know that this is not ideal as it is not the way these floors were intended to function but I am clutching at straws!! A vast majority of the floor seems to be unaffected so I am wondering if I could try something in just the affected areas.
I'd really appreciate peoples thoughts and any advice.
