Has anybody found any way of getting a 4" duct pipe through a two foot thick rubble fill stone wall? I need to fit a fan to a wall of an ensuite bit (basin and toilet). The usual diamond hole cutter you would use on a brick/block wall won't be suitable as the infill will drop and block the hole as you drill through. If there is no way I will have to use a window fan, which is pretty clunky and ugly. Any suggestions?
