mattice
- Worcestershire
Having found the source of our only damp wall in the form of an unventilated suspended floor with a 4ft space below ( the rest of the house has been concreted with the exception of this 5m x 3m section), I spent a weekend putting air bricks in, spent two further weekends with my head torch putting sister joists and vertical supporting posts in... today I went down the hole for what I vowed to be the last time, to finish the job, very pleased to find much less condensation.
As I measured up for my final supporting posts (I want to put a piano on the floor and the joist ends have suffered from wet rot), I tilted my head to one side to avoid the protruding nails from the floor above and my head torch caught a flash of white - the brickwork is absolutely covered in what appears to be cotton wool, or as I now fear dry rot mycelium.
Suddenly I have a free day whilst I contemplate next steps. We're lucky in that all of the other suspended floors have been removed and this is a relatively contained area albeit under the stairs. Next steps? Remove the lovely slate floor rip up the floor boards and joists, treat and fill in? I have a damp guarantee certificate which I suspect will be invalid, why they treated the walls and left an unventilated floor space I do not know!
If there are any words of expertise, reassurance, advice, or even a 'get a grip' it may spur me into attack mode rather my current retreat to the log burner.
- Plan of action seems to be contact the original damp treatment company and get a view on validity of guarantee - assume zero
- find a reputable firm in Worcestershire for a view (any recommendations?)
- strip out the slate - hoping to preserve
- lift the floors
- probably strip the walls (there seems to be polythene membrane from below the floor heading between the joists and the wall upwards behind the plaster
- get a firm in to treat everything
- fill in with hardcore, membrane, concrete, insulation, screed, tiles
As a side note, do you think the fresh air has brought it to the surface?
I suppose the luck part is that after today I would have sealed up my little access hole at the bottom of the stairs, and got on with life until the piano fell through the floor :lol:
- lift the floors
