Glass is a liquid, not a solid. Take a window pane that has been in position for a couple of hundred years and look at it closely. You will always find that it is thinner at the top than at the bottom. Presumably, if you take it out and turn it around, it will flow back the other way over the next few generations
Is this true? - it came from a fairly reliable source (although he's a bit of a hippy!)
